Driggs Posted November 25, 2009 Report Posted November 25, 2009 Replacing my crank and noticed that my Wiseco crank only has one knock pin on the clutch side. Shouldnt I have four? Quote
prb Posted November 25, 2009 Report Posted November 25, 2009 Replacing my crank and noticed that my Wiseco crank only has one knock pin on the clutch side. Shouldnt I have four? No I am also puting in a new wiseco crank.The new cranks have o rings on them to keep them from spinning in the bore instead of pins .Your crank does have 3 orings on the bearing right 1 for each bearing. Quote
Driggs Posted November 25, 2009 Author Report Posted November 25, 2009 Got ya. Yes it does have three orings. I was thinking that was the case. Thanks for the reply. Quote
