Ok i have a banshee that will run out of fuel when i am in higher RPMs i have change my main jet from 310 all the way to a 350 changed pilot jets moved my needle up and down and nothing is working is this even a jetting problem this is what fixed the same problem last time was changing jetting i dont understand whats is going on... little advice would help
this is what is done to my bike K&N's, VForce Reeds, Port Job, Bored to 65mm, CoolHead with 17cc Domes, T5 pipes with CPI silencers, 110 race gas, 40:1
check your float height i had the same problem a while back and it turned out my floats were set to high and not letting enough gas refill the bowls fast enough. which was causing it to spit/sputter/pop at high rpm
Ok i figured it might be that i just have never done that before so can you tell me how to measere my float hieght and how to ajust and what should the hieght be at
you said it was running out of fuel.. so I posted that above. But... a air leak is impossible to jet also.. If you changed jets and the bike didn't run any different. I'd give it a quick leak down test to make sure there isn't a leak.
