joker03banshee Posted November 20, 2009 Report Posted November 20, 2009 i have a 2003 banshee with bills pipes,boysen ss reeds,stock carbs,stock motor,1 tooth less on the front sproket, have 250 mains 25 pilots 3 turns out a.s. i have been tryna get my bike jetted right i have it the closest so far but it seem sumtime it dont wana hit band or sounds like 1 side stops working then cums back.it seems my band will hit every gear sumtimes and the rest in the top 4 gears any idea wat it could be. im at around 1200 ta 1800 ft i ride in it currently stayin around 50 ta 60 degrees. Quote
AKheathen Posted November 20, 2009 Report Posted November 20, 2009 wow, 3 turns is pretty lean on the airscrews. with a 25, you should be 2 turns or less. do you have the airbox/lid/snorkel installed? if not, you are probably pretty lean on the mains. are your carbs cleaned out good? fresh fuel? Quote
joker03banshee Posted November 20, 2009 Author Report Posted November 20, 2009 wow, 3 turns is pretty lean on the airscrews. with a 25, you should be 2 turns or less. do you have the airbox/lid/snorkel installed? if not, you are probably pretty lean on the mains. are your carbs cleaned out good? fresh fuel? yea i have theairbox still on but it never had a snorkel...i drilled holes in the lid for more air should i go up a jet size or 2? Quote
AKheathen Posted November 21, 2009 Report Posted November 21, 2009 yah, i would star at least 2 sizes, then do a proper plug chop, and that will tell you where you are @ on the mains. then work the needles to get the 1/4-3/4 throttle set, then the pilots/airscrews. remember, all adjustments are for a hot engine. Quote
