Drag618 Posted November 17, 2009 Report Posted November 17, 2009 This is my first post. I always have came here and looked for answers and usually find them. Just recently got my motor back from being rebuilt from bottom to top. 4mil and port work. I assembled the motor back to the frame and hooked up all the wireing. Banshee started 1st kick and idled. I warmed the motor up took it for a short ride. Everything was fine. Let cool down checked fluids, and Started it again. warmed motor up for a second time ran good for a few minutes... I then accelerated and was at about 3/4 throttle and it missed or backfired and died. started trying to kick start it but would not start.. head lights would light up as i kicked.. I have no spark. Tried a friends coil it didnt work. Tried a friends cdi it didnt work. Tried a friends run switch it didnt work. by passed the key it did not work. Everything looks good as far as wireing. or at least i think.. what do i need to look at? what could have happened? and help would be appreciated.. Quote
AKheathen Posted November 17, 2009 Report Posted November 17, 2009 cheack and see if your flywhel came loose or something Quote
bansheesandrider Posted November 17, 2009 Report Posted November 17, 2009 Also check your stator- put an ohm meter on the wires per yhe manual or search on here for the specs. The stator has 2 seperate circuits. one for the lights and one for the ignition. So your lights can still come on when kicking it but the ignition side can be bad. Quote
