mexicant Posted November 14, 2009 Report Posted November 14, 2009 so does anyone have any issues with a battery, i have thought about it for a while but dont know where to begin how to hook up and where to mount, any suggestions would be great!!! Quote
bansheesandrider Posted November 14, 2009 Report Posted November 14, 2009 You know to do a battery that you need to do a DC conversion-float the ground in the stator add a rectifier/regulator and modify the wire harness as needed. The only thing you gain with a battery is the ability to run HID lights or to have lights when the engine is off. If you are trying to run more than 70 watts of lights you need a high output stator not a battery. Quote
Snopczynski Posted November 14, 2009 Report Posted November 14, 2009 You know to do a battery that you need to do a DC conversion-float the ground in the stator add a rectifier/regulator and modify the wire harness as needed. The only thing you gain with a battery is the ability to run HID lights or to have lights when the engine is off. If you are trying to run more than 70 watts of lights you need a high output stator not a battery. You can run high output lighting that is brighter than stock but does not exceed 70 watts. LED's draw very little amperage, but the high output vision x stuff is DC, so you have to do the conversion. Quote
