sheerider20 Posted November 9, 2009 Report Posted November 9, 2009 should i go 4 mill or cub? what are the pros/cons of each motor an what are the costs to go either way Quote
RagunCajun Posted November 9, 2009 Report Posted November 9, 2009 (edited) Did you mean stock cylinder 4 mil or stock stroke cub? 4mil means 4mil crank(stroked engine). Cub is aftermarket cylinders. You can do both. Cubs are drag only cylinders(a lot dune ride with them too). 4mil Stock cylinders like i have make for some good mid range power. Perfect for a jack of all trades play bike that will hold it's own in a drag. I wouldnt suggest bolting on cub cylinders and expect the bike to be ready.... With all that said, i wouldnt go cub unless i had a drag only bike. Good luck with your decision. Edited November 9, 2009 by RagunCajun Quote
