AKheathen Posted November 10, 2009 Report Posted November 10, 2009 actually, you can have your head machined to accept noss domes. that way, you can switch them out to 21's to run pump gas again. i still say, porting will make your engine strongest. it should get you 20-35 horse power, at least. Quote
ribordin Posted November 10, 2009 Author Report Posted November 10, 2009 actually, you can have your head machined to accept noss domes. that way, you can switch them out to 21's to run pump gas again. i still say, porting will make your engine strongest. it should get you 20-35 horse power, at least. Then there is a difference between the heads of the banshee and RZ350 ... Here in Brazil this bike is called RD350. I did not know that the United States was called RZ350. Do you think then that if I downgrade my original'll head the same result as a Cool Head Pro Design Billet Head and financially will not be worth much worth spending money on this? What about 4mm stroke Wiseco kit? There a difference between a banshee and the RZ350? Thanks Quote
