rtt Posted November 5, 2009 Report Posted November 5, 2009 Hello All, I just received a new Pro Design foam filter in the mail for my Banshee. The neck or lip that fits over the intake is about two inches wide (has two clamps) and the filter has a metal support inside the filter that comes all the way out to the end of the clamp on area. How does that fit on as the Pro Design intake lip which is only about 3/4 inch wide? Thanks, RTT Quote
MILO Posted November 5, 2009 Report Posted November 5, 2009 Hello All, I just received a new Pro Design foam filter in the mail for my Banshee. The neck or lip that fits over the intake is about two inches wide (has two clamps) and the filter has a metal support inside the filter that comes all the way out to the end of the clamp on area. How does that fit on as the Pro Design intake lip which is only about 3/4 inch wide? Thanks, RTT Slide the metal support screen back into the foam some and use one clamp over the outside to help hold it in place. This should leave you enough of the rubber sleeve to slip over the mounting plate. Us the other clamp to hold it onto the plate. Quote
