gst_r Posted October 28, 2009 Report Posted October 28, 2009 Hi guys....well right now i have an issue with my banshee, it was running perfect then i had a issue with the tranny i get it fixed and also my cases port matched but know when running on wot it just seems to on some kind of rpm limiter this only happens when i am going wot, as soon as i push the throttle, i check for spark plugs, spark, my carbs are clean, from idle to mid throttle seems to run great.... my current jetting is 140 main, 55 pilot, clip on middle, my carbs are 34 PJ, running a mix ratio of 32:1 (4oz per gallon), sea level, right now the temp is 60 to 70F.. it is drag ported, milled head, +4 timing, lightened flywheel... can you help me on what else i can check or look for? or maybe i am off on my jetting... PS. By the way what will be the correct gap for the spark plugs... Quote
KEVSWS6 Posted October 28, 2009 Report Posted October 28, 2009 140 main on drag ported cylinders might be a bit small. Try 160 mains and work down if needed. Quote
gst_r Posted November 1, 2009 Author Report Posted November 1, 2009 thanks man! i put 160 mains it runs better, also check the pick up coil gap.....the only remaining thing is that on idle my spark plugs are getting wet a lot.....i guess i will try some 52 pilots instead of 55 or maybe lower...what you think? Quote
dajogejr Posted November 1, 2009 Report Posted November 1, 2009 Do you have a Ricky stator stator? how about check your connections/grounds. I agree...small main as well. Quote
