Root_Doc Posted October 25, 2009 Report Posted October 25, 2009 Probably a dumb question but, I have the t6 with proper plug chop. Bike runs awesome. Been running awesome for many many hours. Every now and then when I come back to ride my banshee, I notice a small puddle of fuel that has leaked from the carb drain hose. What could be causing this. the drain screw is tight. Float height maybe? Please help Quote
scottzimmerman Posted October 25, 2009 Report Posted October 25, 2009 Probably a dumb question but, I have the t6 with proper plug chop. Bike runs awesome. Been running awesome for many many hours. Every now and then when I come back to ride my banshee, I notice a small puddle of fuel that has leaked from the carb drain hose. What could be causing this. the drain screw is tight. Float height maybe? Please help had the same thing happen to me not all the time but once in awhile it was the needle had something in it took out cleaned it works fine now Quote
Root_Doc Posted October 26, 2009 Author Report Posted October 26, 2009 had the same thing happen to me not all the time but once in awhile it was the needle had something in it took out cleaned it works fine now I will give it a try. Thank you Quote
RedStrapperRacing Posted October 29, 2009 Report Posted October 29, 2009 Had the same problem too man & cleaned the carbs out - all was well. What I did was switch to running amsoil dominator like I use in my kids KTM & YZ dirt bikes and havent had as many problems. The other oil seamed to gum up the carb horribly when some of the fuel evaporated leaving everything gummed up and sticking which led to my fuel pushing up out the over flow. Quote
