Notice that my wheel studs are kind of hard to remove. Was thinking of putting some never seize on the studs, I did this with my car and it works pretty good. Is this safe to try on the banshee?
Thanks
If you are talking about the studs then yes they usually are hard to remove. If you are talking about the lug nuts then they should not be hard to remove. Check the nuts and threads on the studs, if they are hard to get on and off proly need to replace them.
Yes that is safe to use but messy, a little wheel bearing grease would work to just dont use WD-40 or anything like that because believe it or not, the nuts can come loose. You really need to check your threads though because it shouldnt be an issue unless they have been on there forever.
