Mjv420 Posted November 27, 2009 Author Report Posted November 27, 2009 Just a couple things I have on hand laying around ready to ship. IMS/Rolldesign pro pegs Stock intake boots Stock reedcages w/stock reeds Wirtz clutch perch and cable JDS customs footpeg extenders Quote
Mjv420 Posted November 28, 2009 Author Report Posted November 28, 2009 Here are some parts I have left over from the partout. *Stellar M&P bolt-on subframe, bare finish. *IMS RollDesign pro pegs *Parking brake block off *Aftermarket clutch perch & cable *A-arm frame. *Stock rims *3gg wire harness *3gg CDI *2gu ignition coil *Stock voltage reg. *Stock lights *2 sets of stock cases *2 complete Transmissions *Stock steering stem *Stock rear linkage *Stock front and rear shocks *2 Rear master cylinders, 1 front master. *Chain for stock length swinger w/master *Headlight assembly *Keyswitch assembly. *Axle & bearing carrier *2 Clutch covers *Flywheel cover *Stock grab bar *Stock rear brake caliper *Stock front brake calipers *Stock front spindles *Stock a-arms *2 stock radiators Quote
hunter Posted November 28, 2009 Report Posted November 28, 2009 I am parting out a banshee. Im located in southern indiana, prices listed do not include shipping. For payment I will accept paypal and USPS money orders, add 2% to total price if using paypal. If there is a stock part you need but do not see it listed below please inquire about it via PM. I will entertain offers, but please do not try lowballing. A arm frame w/stellar sub frame - $250 Hiper beadlocks /front & rear /blue beadlocks - $500 ITP Holeshot 10" fronts / Maxxis Razr 9" rears - $140 DMC 916 exhaust system - $350 IMS/Roll Design pegs - $150 JDS Customs foot peg extenders mounted on stock pegs - $55 Pro Design coolhead w/22cc domes /new o-ring kit - $150 Aftermarket clutch perch w/clutch cable - $35 Iron cross front exhaust hangers - $15 Fly racing handlebars w/fly grips - $25 Aftermarket non-oring chain w/master link /stock length - $15 Parking brake block-off - $8 Billet water pump impeller - $35 Stock cylinders w/pistons /stock port - $275 Stock carbs w/tors elimination kit /slides and caps/ throttle cable /K&N pods - $115 Stock cases /no chain whack - $170 3gu wiring harness - $60 3gu CDI - $70 3gu Ignition coil - $40 Stock stator /w pickup coil and stator plate - $75 Ricky stator w/pickup coil - $60 Ricky stator adjustable timing plate - $45 Stock rubber pipe clamps - $10 Front brake master cylinder - $25 Rear brake master cylinder - $20 Stock Transmission - $150 Quote
hunter Posted November 28, 2009 Report Posted November 28, 2009 do you still have the water pump impeller i'm interested [email protected] Quote
Mjv420 Posted November 28, 2009 Author Report Posted November 28, 2009 do you still have the water pump impeller i'm interested [email protected] I more than likely have a stock impeller, billet impeller is sold. Make offers guys, wanting to move this stuff. Quote
