Hey everyone, I just picked up a 1994 Banshee last night. It was just barely running when I got it, and after taking it for a quick drive when I got it home, it lost spark. I checked the coil and it was just out of spec so I replaced it. There was still no spark. The coils on the stator checked out, but I took off the flywheel and found that the woodruff key had sheered off. I replaced the woodruff key, and started the Banshee up on the third kick. I had left the stator cover off, and when it was running, it was arcing like crazy by the pickup. Is it normal to see electric arcs by the pickup? I've run my Blaster without the Stator cover before and have never noticed any sparks. There was also some smoke coming from around the stator area. As soon as I saw this I shut it down and haven't started it back up. Everything else seemed fine while it was running though. It revved fine and there was no odd pinging/knocking/squeals coming from anything.
If anyone has any insight, it would be greatly appreciated!
No, arcing is not a normal condition. Not really sure where you are experiencing this arc but wondering if your grounds are no good thus causing the fly wheel to try and reach a ground loop through the PG. The PG does not make enough power to build a health blue spark. I would pull the flywheel and stator and see if you can determine the origin as well as test all ground points. IF not, the stator will surely die very soon.
Good luck!
Brandon
Mull Engineering
