Just got my banshee back together and it runs really nice till I try to pull high rpms or decelerate from high rpms. Then It's like I turned off the key. I can pull in the clutch and as soon as the motor stops spinning bump start it and drive away. Not a fuel problem at all, everything there is all good. Jetting is on the safe side. TORS is gone. Absolutely will not fire again till it has stopped spinning. The second it does, it will start with the slightest kick. If I let the atv push the engine it wont even pop again till it has stopped and I kick it over. Then it fires like nothing ever happened. Any thoughts?
