FitZBanshEe Posted October 4, 2009 Report Posted October 4, 2009 My banshee will jump start first try but it won't kick start..when it runs it's also a litle laggy and the idle is weird..it won't idle it jus turns off...is this a problem with the carbs or compression? Both pistons and walls are perfect Quote
Drewski Posted October 4, 2009 Report Posted October 4, 2009 I would check your compression first off then take it from there Quote
FitZBanshEe Posted October 4, 2009 Author Report Posted October 4, 2009 Just did the compression is fine Quote
Drewski Posted October 4, 2009 Report Posted October 4, 2009 Just did the compression is fine then it must be carburation issues. might try posting in the jetting forum for better results. sorry i don't know much about carbuation Quote
SAVAGE420 Posted October 4, 2009 Report Posted October 4, 2009 Just did the compression is fine Whats fine though? How much per hole? Quote
