Burt Reynolds Posted October 4, 2009 Report Posted October 4, 2009 Ok i have a set of denton racing j arms on my banshee. They have bronze bushings. Well they are worn out so i bought some stock style delron j arm bushings. Come to find out the denton j arms use a different size bushing,they have a little bit of a smaller outer diameter,but have the same inner diameter so you can use the stock banshee bolt and tube. I measured the stock banshee j arm tube,where the bushing pushes in,it is just over 20mm. The denton racing tube where the bushing pushes in is roughly 18.7mm I have tried and tried to find something on denton racing,but i think they are gone,the website doesnt work and the phone number i found is disconnected.Also i cant find any of their products besides the stabilizer anywhere. So WTF can i do? I could have a machine shop machine the tubes to where they will work with stock bushings,and still be strong(they have a thick wall),but i would rather find some bushings that will work? Anyone ever heard of this? This is a damn headache Quote
SAVAGE420 Posted October 4, 2009 Report Posted October 4, 2009 (edited) Just be careful and use a dremel with a lil sanding wheel drum to take a lil bit off the outsides of them all the way around slowly. Simple fix and will take 1/2 an hour at the most to do them all. If no dremel then use a drill with a lil sanding wheel drum..come on now ELI!!!! Edited October 4, 2009 by savage420 Quote
JKJK Posted October 4, 2009 Report Posted October 4, 2009 Richard's Bushings 413-443-1141 In Pittsfield Ma.Give Rich a call,he's a good guy+probably has what you need. Quote
