Ok i have a set of denton racing j arms on my banshee. They have bronze bushings. Well they are worn out so i bought some stock style delron j arm bushings.
Come to find out the denton j arms use a different size bushing,they have a little bit of a smaller outer diameter,but have the same inner diameter so you can use the stock banshee bolt and tube.
I measured the stock banshee j arm tube,where the bushing pushes in,it is just over 20mm. The denton racing tube where the bushing pushes in is roughly 18.7mm
I have tried and tried to find something on denton racing,but i think they are gone,the website doesnt work and the phone number i found is disconnected.Also i cant find any of their products besides the stabilizer anywhere.
So WTF can i do? I could have a machine shop machine the tubes to where they will work with stock bushings,and still be strong(they have a thick wall),but i would rather find some bushings that will work?
Anyone ever heard of this? This is a damn headache
Just be careful and use a dremel with a lil sanding wheel drum to take a lil bit off the outsides of them all the way around slowly. Simple fix and will take 1/2 an hour at the most to do them all.
If no dremel then use a drill with a lil sanding wheel drum..come on now ELI!!!! whoopass.gif
Edited by savage420
