bbcmudtruck Posted September 24, 2009 Report Posted September 24, 2009 I need the lower bushing for both of the front shocks. Where would I even look for new ones, if nobody has used ones laying around? Quote
bbcmudtruck Posted September 24, 2009 Author Report Posted September 24, 2009 I'm looking for two bushings like the one in this pic. Quote
370banshee Posted September 24, 2009 Report Posted September 24, 2009 (edited) thats weird.. i check the microphish and you can't get that part BUT you can get the upper bushings... very weird.. if you can't find em used you may have to make friends with a machinst i wonder if you can use teh upper bushing in the bottom mount? older banshee shocks had a rubber mounted bushing in both ends.. that upper bushing is only $9 might be worth a shot. Edited September 24, 2009 by 370banshee Quote
