but it shoots out tranny fluid
Then pressure is building up in the side case, ie. crank seal is bad. Are you smoking a lot out the right side exhaust more so then before? Is your fluid getting low?
how much oil is comming from that tube? if it's pumping lots of tranny fluid out of that hose then it might mean that you have a bad pto side crank seal...
You must have missed this guys' post? We need all the info to determine what your issue is, do a leakdown to determine if the seal is bad. Here's the sticky thread of doing a leakdown: LEAKDOWN TESTER
