Got my banshee running good enough to ride it around a little, it idles on one cylinder though. IF I pull the choke one notch out, both cylinders idle. I turned on the screws on the side and nothing really happened. THe right side was running, just not lke the right. Adjusted on the right side cable and it never picked up. Took it down the road wide open and it ran about 25 ft on one cylinder then the right side fires and it pulls both wheels off the ground. This thing is freakin scary fast on both cylinders. Where should i start??
Yep. the air fuel is the screw on the side, right?? What is a good starting point there?? It is running, cause the exh. is hot so i know it has to be just something small. Can anyone tell me why the choke makes it run???
Edited by Michael66
iit seems like you're not getting the right gas flow to the engine, i blew up once cylinder on my shee, so it still starts but sounds like hell.
I put a new thumb throttle on it and adjusted the top screws on the tors individually and guess what? IT RUNS ON 2 NOW!!!!!
