What kind of octane are you using? Im pretty sure 110 octane is safe for that much compression but if your running pump gas like 94 octane then I think around 155 psi with +4 timing is about the limit. I use 21cc cut domes with my 4 mil for 155 psi.
I run 100 octane at 181 psi
SUNOCO 110
More then enough.
