bansheemaniac1 Posted August 30, 2009 Report Posted August 30, 2009 On my stock cylinders, what domes can i get by with using pump gas? And do i use the stock copper gasket or not with the pro design head? thanks, bmaniac Quote
bbcmudtruck Posted August 30, 2009 Report Posted August 30, 2009 http://www.nossmachine.com/banshee_heads.htm You need to know your elevation, there is a chart midway down the page. I think most people run 91 up to 150psi and then start blending race gas with 91 after that. Quote
alf44 Posted August 30, 2009 Report Posted August 30, 2009 The coolhead comes with o rings. you wont use the stock gasket. 20cc domes will be fine. Quote
bansheemaniac1 Posted August 30, 2009 Author Report Posted August 30, 2009 The coolhead comes with o rings. you wont use the stock gasket. 20cc domes will be fine. cool. thanks for the info !!! Quote
