rubeat Posted August 28, 2009 Report Posted August 28, 2009 Will a tors removal throttle cable kit work on these? If not can someone give me a link to a throttle cable that will work. Thanks Mike Quote
Snopczynski Posted August 28, 2009 Report Posted August 28, 2009 I think thats the one that works. The end on mine looks like the end on a eliminator kit cable for a thumb throttle. I have a twist throttle though. Quote
rubeat Posted August 29, 2009 Author Report Posted August 29, 2009 I thought they would but wasn't for sure.Do you like your 28s?I know they will take the stock 26 main jets but will they take the pilots? Thanks Quote
Snopczynski Posted August 29, 2009 Report Posted August 29, 2009 they use different pilot jets. Quote
rubeat Posted August 29, 2009 Author Report Posted August 29, 2009 they use different pilot jets. Ok thanks Quote
Coupelx Posted August 29, 2009 Report Posted August 29, 2009 yes just get a cable for tors removal. thats what i run on mine and fits perfect. get one with the 45* angle on the carb ends so it wont want to kink the cable at the top of the carb. Quote
mopar1rules Posted September 6, 2009 Report Posted September 6, 2009 yes just get a cable for tors removal. thats what i run on mine and fits perfect. get one with the 45* angle on the carb ends so it wont want to kink the cable at the top of the carb. where do you get the one w/the 45* angles? mine has 90deg angles and its the one that came w/the tors removal kit. Quote
