I am finishing my rebuild and need a starting point.
Aggressive dune port, second overbore.
Stock head,stock compression,
Toomey t-5 system
Stock carbs.Tors in the junk pile.
Stock timing plate but adjustable plate on order.
Pro flo adapter w/ K&n no lid
sea level. 80s-90s temperature here now.
I have stock needles and plenty of mains and pilots. I will be running 93 octane with 32-1 maxima 927
I would like to know a good point to start
air screws how many turns
what slot to put the clip on the needle
pilot and main
I hope thats enough info for some ballpark jetting suggestions. I looked through the jetting thread but couldnt find my exact setup.Thanx for help.
Edited by dufrain
i would start with 330 mains, needle in the middle, 25 pilot, airscrews @ 1.5 turns from seated. get her warmmed up, and do a proper plug chop, then play with the needle if the mid throttle has issues, and airscrews to get the off-idle operation. less than 1 turn on airscrews, increase pilot 1 size. more than 2.5, go back down. syncing really helps it to run good, too.
