Ok, My left hand side Mikuni Carb leaks/dribbles fuel out the verrry bottom port. I believe that is the drain port. Well I took out the carb drain screw and cleaned it off, put teflon tape on it, and tightened it all the way back in. The port still leaks/dribbles out fuel when I am on the throttle, etc...
any insight?
Thanks, I have learned a lot in the weeks I just got on here!
any insight?
Your float is set to low in that carb, Raise it up a mm or so and be done.
Could be your seat also but its proly your float. Set it and be done.
I never worked on a carb or seen much into one. new at this. could be interesting. THANKS!
I thought if the float was out of spec, the overflow tube would puke fuel. NOT the lower very bottom drain port under the bowl
HAHA sorry read that wrong i thought you meant the over flow was leaking
Well if its the drain plug like you just said there should be an o-ring in the drain plug for it to seal when screwed up into the bowl. Go check it out.
no, there still is a little dump tube in the bowl that bypasses the drain screw when the fuel is too high. back to float adjustment :thumbsup:
