STINKYDELUXE Posted August 17, 2009 Report Posted August 17, 2009 I would say 18mm or bigger with a DM, DMX or big Twister is a safe bet I've heard of turbos throwing up big numbers but tuning is vary difficult. just my .02 Quote
dajogejr Posted August 17, 2009 Report Posted August 17, 2009 10K and at least 600 cc's of naturally aspirated, You could build a 10 mil cub and spray 25 a hole...that will get you there. Up to you. Quote
jones20992 Posted August 17, 2009 Author Report Posted August 17, 2009 (edited) matoon cases for 1 check iam thinking +12 76mm Edited August 17, 2009 by jones20992 Quote
shanYE west Posted August 17, 2009 Report Posted August 17, 2009 billet cases are not "needed". Quote
FireHead Posted August 17, 2009 Report Posted August 17, 2009 billet cases are not "needed". I agree. A 10mil is about the minimum stroke-wise that you can get that kind of power out of. :geek: Quote
jones20992 Posted August 17, 2009 Author Report Posted August 17, 2009 (edited) billet cases are not "needed". what do you feel is needed for a build of this level also i am open to the use of water/ meth injection and ....would ypvs be a bad idea ? Edited August 17, 2009 by jones20992 Quote
2/2 many banshees Posted August 17, 2009 Report Posted August 17, 2009 also i am open to the use of water/ meth injection and ....would ypvs be a bad idea ? YPVS why and how ?? Quote
shanYE west Posted August 17, 2009 Report Posted August 17, 2009 Simple 10mil cub on stock cases with a shot of NOS should net you in the 150's (depending on whos dyno) if your looing to keep it on motor. 18mil DMX are being done on stock cases by numerous builders and are getting around 180's.. There is alot of ways to do it.. the question is.. how deep is your pocket. Quote
jones20992 Posted August 17, 2009 Author Report Posted August 17, 2009 how about this 635cc T-REX Cylinder kit for Banshee. 76 mm Bore for 16mm stroker cranks with 130 mm long rods. Part# T-REX7670 ypvs delta v force reeds race port ? Quote
dajogejr Posted August 17, 2009 Report Posted August 17, 2009 With a lot of porting, maybe.... Before I went with a TRex setup, I'd go billet twister or dm/dmx cylinder. Quote
shanYE west Posted August 17, 2009 Report Posted August 17, 2009 how about this 635cc T-REX Cylinder kit for Banshee. 76 mm Bore for 16mm stroker cranks with 130 mm long rods. Part# T-REX7670 ypvs delta v force reeds race port ? on alky with the right porting, domes and carb setup.. maybe.. Quote
