DannysZ28 Posted August 22, 2009 Author Report Posted August 22, 2009 my buddies shee used to break up on top end and it turned out to be the coil. do you have a buddy that could borrow you a coil for testing? Well you hit the nail on the head. I went to take the coil off to check it i noticed that the wires were very loose on the coil The orange wire almost fell off of the connector when i touched it. Took some pliers and tightend up the connectors, put them back on and it ran perfect. I really hope this is all the problem turns out to be. Since the problem started after changing pipes, i really thought it was in the jetting. I guess i changed all those jets for nothing but al least it turned out to be a quick fix. Thanks for all the help guys. Quote
mopar1rules Posted August 23, 2009 Report Posted August 23, 2009 no problem....glad you found the issue. Quote
