GhostRider Posted July 26, 2009 Report Posted July 26, 2009 Hello guys ... when i go riding .. and right after doing some wheels ... after 3 or 4 long wheels ... my banshee back firing and sounds like losing power when poping the clutch to get the front end up... the weather temp is between 105-115F ... this is not the first time .. everytime i go riding after doing some wheels ... it back firing when im poping the clutch ... before 2 months i changed the crank seals .. and someone told me that one of my crank arm got heat on it by its colour ... but he said its ok .. so i didnt changed the arm ... so do you think the problem is my banshee is over heating cause of heated crankarm? or the weather? ... and thanks changed the spark plugs i got bills pipes and k&n pods ... 200 main didnt jetted the carb Quote
captainhowdie Posted July 26, 2009 Report Posted July 26, 2009 Your way too lean. Start at a 310 main and work your way down Quote
slopoke Posted July 26, 2009 Report Posted July 26, 2009 first off the crank throws are susposed to be blued from the heat applied when putting them together, second the carbs may be running out of fuel, a banshee or any other wheeler for that matter i not designed to do long wheelies. the carbs are not level and in a vertical or near position the floats are prob closing Quote
slopoke Posted July 26, 2009 Report Posted July 26, 2009 you may also ck ur reeds and the gaskets around them for air leaks Quote
97stageIVBansh Posted July 26, 2009 Report Posted July 26, 2009 Hello guys ... when i go riding .. and right after doing some wheels ... after 3 or 4 long wheels ... my banshee back firing and sounds like losing power when poping the clutch to get the front end up... the weather temp is between 105-115F ... this is not the first time .. everytime i go riding after doing some wheels ... it back firing when im poping the clutch ... before 2 months i changed the crank seals .. and someone told me that one of my crank arm got heat on it by its colour ... but he said its ok .. so i didnt changed the arm ... so do you think the problem is my banshee is over heating cause of heated crankarm? or the weather? ... and thanks changed the spark plugs i got bills pipes and k&n pods ... 200 main didnt jetted the carb stock carbs? if they are stock youre main sounds way lean, with my stock carbs pipes and filters i had a 320 main Quote
slopoke Posted July 26, 2009 Report Posted July 26, 2009 oh my i missed the 200 mains wow that seems really lean Quote
GhostRider Posted July 26, 2009 Author Report Posted July 26, 2009 Oki guys i will get a jetting kit and try it again and see .. Quote
GhostRider Posted July 26, 2009 Author Report Posted July 26, 2009 i forgot ... if its from the jetting then why its not back firing at the first 10 minutes of riding? banshee is back firing only when i pop the clutch not at normal riding ... Quote
