I just bought a set of Pro circuit pipes for my 07 Banshee pretty much stock except for a dura blue filter with air box lid vented and now the pipes. I was told to start with a 340 main and a 27.5 pilot with the clip in the middle of the stock needle. Do you guys think that sounds about right im at about 3 to 400 feet above sea level. Since ive done this it takes many kicks to get started now when its cold and before it would start with in 3 kicks with the stock pipes. any opinios would help
way to high on the mains.
I run 320 and have pod filters, same pipes
start with 280 and see how it runs.
that is ofcourse your elevation is around 1200'
you must adjust the jetting from a known base to match your elevation.
it is not spot on, but will get you in the ball park. there are many other factors but should get you close.
works fine except for its takes more kicks to get it started after it sits for a few days. I think im gonna try some 320 mains it it to see if that make it work any better, im sure thats not why it not starting good though.
