hyperpro
Everything posted by hyperpro
  1. I just bought a set of V Force reeds for my banshee, Will I have to rejet my carbs if so how many sizes should I go up on the mains
  2. My compression is 117psi on each side. I check the float bowls and they are on the proper side
  3. 400 Feet above sea level and i drive in 15 to 25 degree weather.
  4. I have a Banshee with PCP pipes with a dura blue filter stock carbs with 320 mains and 27.5 pilots and it seems that the choke is not working on the right cylinder. The engine is very hard to start but when it dose start the right cylinder will kick in after a bit. Once it starts it works fine but just hard to start cold. Any ideas of what it could be
  5. What should a stock Banshee engine have for compression?
  6. works fine except for its takes more kicks to get it started after it sits for a few days. I think im gonna try some 320 mains it it to see if that make it work any better, im sure thats not why it not starting good though.
  7. I just bought a set of Pro circuit pipes for my 07 Banshee pretty much stock except for a dura blue filter with air box lid vented and now the pipes. I was told to start with a 340 main and a 27.5 pilot with the clip in the middle of the stock needle. Do you guys think that sounds about right im at about 3 to 400 feet above sea level. Since ive done this it takes many kicks to get started now when its cold and before it would start with in 3 kicks with the stock pipes. any opinios would help
