broke as a joke Posted July 25, 2009 Report Posted July 25, 2009 One main size for every 1750 to 2000 feet is the rule of thumb, I'm going from 1400 feet to 600 feetish to go to silver lake, should I plan on being ok on jets? Or will I need to adjust a little? Quote
rmkboxer Posted July 25, 2009 Report Posted July 25, 2009 One main size for every 1750 to 2000 feet is the rule of thumb, I'm going from 1400 feet to 600 feetish to go to silver lake, should I plan on being ok on jets? Or will I need to adjust a little? it depends where you are jetted at. if you are not borderline on your jetting you should be fine. but I would do a couple of passes with it and check your plugs. but you should be ok. Quote
