Decided to move on up to the Eastside and some powervalves so this stuff's got to go. everything is off of 421 cub. no dibs. prices do not include shipping. my zip is 97304. if someone wants a combination of parts ill drop the prices some
Polished cub cylinders with 68mm bore (will not work with stock crank. set up for 4 mill long rod). the polish job isn't the greatest, but i'm pretty picky. in the pics i've circled a couple flaws, and there are some little scratches from a wrench around the forward nuts that bolt cylinders to case. the head studs are not included. $750
brand new 68mm blaster pistons with rings pins and bearings - $125
pro design cool head. comes with studs, o rings, new 19cc domes, and used 22cc domes - $175
used 19cc pro design domes for stock bore (one was dropped - u can see dent in the picture - but continued using these and it didn't affect the oring seal) - $30
aluminum reed spaers - $25
vforce 2 reed cages in good shape - $85
pro design 34-35mm intake manifolds with no crossover - $150
brand new polished quick change lockout cover. this is not a 1 piece cast, but a stock one that's been modded and epoxied. upgrading to 1 piece cover. lockout assembly, water pump cover, and dipstick not included. - $200
pro design billet water pump $40
vito's super stock forged "ported" pistons and rings. one is brand new, the other is slightly used. they're either .020 or .030 over, but i don't have my caliper right now. i'll post size once i know tonight. i don't have the pins or pin bearings for these. - $30
stock head and stator cover - $10 each (will send pics upon request)
Cubs, cub pistons, clutch cover, water pump, v forces 2s, and intakes, all SOLD
pro design head with studs, orings, and either used 19s or used 22s: 140 shipped
pro design domes: new 19cc: $40 shipped; 19cc or 22cc (both used): $30 shipped
reed spacers: $25 shipped
vitos pistons: $25 shipped
  • 8 months later...
