i have a banshee project i am willing to trade for a 250R atv of any sort or any 450 maybe add some cash the banshee pretty much just needs put back together and some nuts and bolts for plastic and stuff like that. the motor is bored .040 over wiseco pictons has some home drag port done to it. has plastic that has been painted black then clear coated frame was spray painted green then cleared. it has alumilite handlebars motor is somewhat fresh i think it only has break-in time on it. each cylinder has 175 psi compression in it. all you will need for this bike is a kill switch a different tie rod end and some time to put this beast back together. i have a brand new full gasket set for whoever buys it and an extra tank and shroud it has 34mm pj carbs it will come with a twist throttle and thumb throttle if any pictures are wanted of this bike e-mail me at [email protected] and i will send pictures on there or you can pm me your phone number and i will send pictures over cellphone. i want 1600 for all this its worthmore than that it is nearly a complete bike the motor needs put back in tie rod end needs put on wire a killswitch to it add fluids and start it up and run it. i dont have time for this bike anymore thanks for looking or i will take any trade for a fast atv.
