Hi,
Ive been searching on the forum for jetting of a STD stroke CUB 65mm with no success. I am really battling jet the 33mm carbs, and the closest I have come to correct is 160 mains, 52 pilots, cel on center, 1.5 turns.
Please if you guys can help me on this one. I have the following: 65mm STD stroke CUB with cleanup, 33mm PWK carbs, Boyesen dual stage reeds, 6" K&N Pods, DMC 916 pipes and I am at sea level. Running gas at 32:1 on belray. Temps from 20-30C
Thanks guys
where is the bike acting up at what part of the throttle
to me your main seems lil big
and talk in f dont know what deg c would be.
  • 2 weeks later...
The pipes are probably hurting the top end. GO up on the mains and see if it runs better. If it runs worse, then go the other way. Do a WOT plug check also.
