ALL PARTS ARE PLUS SHIPPING
RADIATOR W/HOSES $35
SWINGARM $30
WISHBONE $15
BEARING CARRIER $30
A ARMS SET $80
TIE RODS $20
SPINDLES $30
FRONT HUBS $25 A SET
FRONT BRAKE CALIPERS $40 A SET
FRONT BRAKE ROTORS $10 A SET
REAR HUBS $15 EA.
UPPER RIGHT A ARM $20
LOWER RIGHT A ARM $20
LOWER LEFT A ARM $20
GRAB BAR $10
FRONT SHOCKS $50 A SET
REAR SHOCK $50
BRAKE HUB $15
CHAIN TENSIONER $10 A SET
DOMES 18CC $30
RADIATOR CHROME CAP COVER $10
HEAD GASKET $5
REED SPACERS $20
PETCOCK $10
REED CAGES W/BOSYSEN $25
INTAKES $15
34-35MM INTAKES $40
CARBS $50
CHROME CLUTCH COVER INSERT $15
CLUTCH COVER $25
LEFT SIDE CYL 68MM PORTED $50
HEAD $15
REAR BRAKE CALIPER $40
2000 CDI BOX $40
K&N AIR FLITERS FOR 35MM CARBS $35
CRANK $60
REAR BRAKE MASTER $25
REAR BRAKE PEDAL $10
FRONT BRAKE MASTER $15
FOOT PEGS $25
10"ITP WHEELS $40
20X11X9 TURBO PADDLES W/WHEELS 2 HOLES ARE WALLERD OUT $75 STILL WORK FINE
21X12X8 SL HAULERS 9 PADDLES WORN DOWN BUT NOT TO BAD $75
CYLINDERS FULL PORT ON FIRST BORE NEED HONE $300
SWINGARM $30
WISHBONE $15
BEARING CARRIER $30
A ARMS SET $80
TIE RODS $20
SPINDLES $30
REAR HUBS $15 EA.
GRAB BAR $10
REAR SHOCK $50
BRAKE HUB $15
DOMES 18CC $30
HEAD GASKET $5
REED SPACERS $20
PETCOCK $10
INTAKES $15
34-35MM INTAKES $40
CARBS $50
CLUTCH COVER $25
HEAD $15 SOLD
2000 CDI BOX $40
CRANK $60 SOLD
FOOT PEGS $25
10"ITP WHEELS $40
21X12X8 SL HAULERS 9 PADDLES WORN DOWN BUT NOT TO BAD $75 SOLD
HAULERS/CRANK/HEAD ALL SOLD
