tiffnaub Posted July 6, 2009 Report Posted July 6, 2009 ALL PARTS ARE PLUS SHIPPING RADIATOR W/HOSES $35 SWINGARM $30 WISHBONE $15 BEARING CARRIER $30 A ARMS SET $80 TIE RODS $20 SPINDLES $30 FRONT HUBS $25 A SET FRONT BRAKE CALIPERS $40 A SET FRONT BRAKE ROTORS $10 A SET REAR HUBS $15 EA. UPPER RIGHT A ARM $20 LOWER RIGHT A ARM $20 LOWER LEFT A ARM $20 GRAB BAR $10 FRONT SHOCKS $50 A SET REAR SHOCK $50 BRAKE HUB $15 CHAIN TENSIONER $10 A SET DOMES 18CC $30 RADIATOR CHROME CAP COVER $10 HEAD GASKET $5 REED SPACERS $20 PETCOCK $10 REED CAGES W/BOSYSEN $25 INTAKES $15 34-35MM INTAKES $40 CARBS $50 CHROME CLUTCH COVER INSERT $15 CLUTCH COVER $25 LEFT SIDE CYL 68MM PORTED $50 HEAD $15 REAR BRAKE CALIPER $40 2000 CDI BOX $40 K&N AIR FLITERS FOR 35MM CARBS $35 CRANK $60 REAR BRAKE MASTER $25 REAR BRAKE PEDAL $10 FRONT BRAKE MASTER $15 FOOT PEGS $25 10"ITP WHEELS $40 20X11X9 TURBO PADDLES W/WHEELS 2 HOLES ARE WALLERD OUT $75 STILL WORK FINE 21X12X8 SL HAULERS 9 PADDLES WORN DOWN BUT NOT TO BAD $75 CYLINDERS FULL PORT ON FIRST BORE NEED HONE $300 Quote
Okie450 Posted July 6, 2009 Report Posted July 6, 2009 Pics of the haulers to [email protected] Quote
dkripper Posted July 6, 2009 Report Posted July 6, 2009 DO YOU STILL HAVE THE CHROME CLUTCH COVER INSERT ?????? Quote
tiffnaub Posted July 6, 2009 Author Report Posted July 6, 2009 DO YOU STILL HAVE THE CHROME CLUTCH COVER INSERT ?????? yes $20 shipped Quote
tiffnaub Posted July 6, 2009 Author Report Posted July 6, 2009 Pics of the haulers to [email protected] pics sent $100 shipped Quote
ktKid Posted July 6, 2009 Report Posted July 6, 2009 Can you shoot me a pic of the haulers please. [email protected] Good chance I'll take them Thanks Quote
Okie450 Posted July 6, 2009 Report Posted July 6, 2009 Whats you're paypal and I will pay for the tires pics looked good. Quote
tiffnaub Posted July 7, 2009 Author Report Posted July 7, 2009 ALL PARTS ARE PLUS SHIPPING RADIATOR W/HOSES $35 SWINGARM $30 WISHBONE $15 BEARING CARRIER $30 A ARMS SET $80 TIE RODS $20 SPINDLES $30 FRONT HUBS $25 A SET FRONT BRAKE CALIPERS $40 A SET FRONT BRAKE ROTORS $10 A SET REAR HUBS $15 EA. UPPER RIGHT A ARM $20 LOWER RIGHT A ARM $20 LOWER LEFT A ARM $20 GRAB BAR $10 FRONT SHOCKS $50 A SET REAR SHOCK $50 BRAKE HUB $15 CHAIN TENSIONER $10 A SET DOMES 18CC $30 RADIATOR CHROME CAP COVER $10 HEAD GASKET $5 REED SPACERS $20 PETCOCK $10 REED CAGES W/BOSYSEN $25 INTAKES $15 34-35MM INTAKES $40 CARBS $50 CHROME CLUTCH COVER INSERT $15 CLUTCH COVER $25 LEFT SIDE CYL 68MM PORTED $50 HEAD $15 SOLD REAR BRAKE CALIPER $40 2000 CDI BOX $40 K&N AIR FLITERS FOR 35MM CARBS $35 CRANK $60 SOLD REAR BRAKE MASTER $25 REAR BRAKE PEDAL $10 FRONT BRAKE MASTER $15 FOOT PEGS $25 10"ITP WHEELS $40 20X11X9 TURBO PADDLES W/WHEELS 2 HOLES ARE WALLERD OUT $75 STILL WORK FINE 21X12X8 SL HAULERS 9 PADDLES WORN DOWN BUT NOT TO BAD $75 SOLD CYLINDERS FULL PORT ON FIRST BORE NEED HONE $300 HAULERS/CRANK/HEAD ALL SOLD Quote
tiffnaub Posted July 7, 2009 Author Report Posted July 7, 2009 HAULERS/CRANK/HEAD ALL SOLD CDI BOX SOLD THANKS Quote
Infamous039 Posted July 7, 2009 Report Posted July 7, 2009 Please Send Pics of 10" ITP wheels to ( [email protected] ) Thanks Quote
#1JUANstunna Posted July 7, 2009 Report Posted July 7, 2009 Payment sent for rear master cylinder. Quote
