Drewie Posted June 29, 2009 Report Posted June 29, 2009 Hi All. I have a 09 banshee and its got Pipes FMF Upgrade Reed Upgrade Tusimi Jet Kit To match Pipes. and was going not too bad until i removed the Torrs, i bought from the States torr remove kit. took off the carb tops did the idle screws removed the torrs little black box. started her and all seemed great. took her for a big weekend away. then got smoke from one pipe rich.. and it seemed it wouldnt rev to its limit anymore. pulled the carbs down blew out the jets readjusted the needles played with air screws. then figured it was electrical. pulled the handbrake on and tryed to rev it and it wouldnt . i thought that removing the torrs stopped that. have i overlooked a electrical component that i need to remove as well. i cant find the problem. should i put the torrs back on, as it was a lot better running when the torrs was on. and only started this underrev thing when i remove the torrs.??? i have a electronic dash on her as well could this be a source of the problem too?? any advice will be appreciated. Thanks Drew South Australia. Adelaide.. Quote
