JoeTeamMayhem Posted June 29, 2009 Report Posted June 29, 2009 I'm looking into a ti bolt kit. If i took the time i could piece one together, but i'm new to the banshees so im not exactly sure where to start looking. Any info will help i need the 2 lower a arm bolts, swingarm pivot, rear shock bolts, front shock bolts and motor mounts. Thanks! Quote
docjcwatson Posted June 29, 2009 Report Posted June 29, 2009 I'm looking into a ti bolt kit. If i took the time i could piece one together, but i'm new to the banshees so im not exactly sure where to start looking. Any info will help i need the 2 lower a arm bolts, swingarm pivot, rear shock bolts, front shock bolts and motor mounts. Thanks! Try Racebolts.com... OR Head over to YFZtech.com and send EKO Engineering a PM. His name is Dustin, and his main focus is Ti chassis parts and bolts. I'll warn you now, before you start looking. Just the swingarm pivot bolt, in Ti, is like $200. Quote
JoeTeamMayhem Posted June 29, 2009 Author Report Posted June 29, 2009 Try Racebolts.com... OR Head over to YFZtech.com and send EKO Engineering a PM. His name is Dustin, and his main focus is Ti chassis parts and bolts. I'll warn you now, before you start looking. Just the swingarm pivot bolt, in Ti, is like $200. Thanks. I'm very familiar with EKO i had some of their stuff on my YFZ and it was all top notch quality. I was searching for other alternatives to see if anybody had a banshee specific kit they sold. So far nothing much to write home about. Yea its expensive stuff, but there arent many other spots we have left to save weight and still be safe on whooped out dune flats. Thanks again for the info. Anything else is much appreciated. Quote
