drunkietheclown Posted June 25, 2009 Report Posted June 25, 2009 i have an 04 banshee(described in my profile) and i have been having problems with it lately, it will not idle at all, it has no low end torque, and it will not kick start, i have to jump start it. mods in my profile if that will help diagnose these problems. Quote
LiftdT4R Posted June 26, 2009 Report Posted June 26, 2009 Post up your mods here, its alot easier. How many hours are on the bike, and did it start all of a sudden? Could be a couple things, it could be that 1. Carb Jetting is incorrect 2. Carbs are really dirty and need to be rebuilt 3. Weak spark (take the plug out, turn off the gas, and let the plug with the wire attached rest against the head DONT HOLD IT, and kick the bike. You should see a fat blue spark) 4. Low Compression (if the bike has a lot of hours or the jetting was wrong for too long, the cylinder bore could be worn down and it may be time to rebuild) Quote
drunkietheclown Posted June 26, 2009 Author Report Posted June 26, 2009 engine has 12 hours on it since rebuild and mods installed minus the exhaust, the compression is higher than stock because of the milled head. don't know the exact reading. it's easy to kick over but impossible to start via kicking unless it's completely warmed up. Milled head wiseco high compression pistons full pro circuit exhaust barnett dirt digger clutch and basket TORS eliminator (seems to like to run me into trees...) and K&N 2 into 1 airbox. yes i had these problems before i smoked the tree. by the way anyone in canada have a stock lower left control arm they could sell me? Quote
AKheathen Posted June 26, 2009 Report Posted June 26, 2009 was the battery hard to find for a jumpstart? :biggrin: Quote
SonOfSand Posted June 26, 2009 Report Posted June 26, 2009 Have you recently had the bowls off the carbs? Quote
slopoke Posted June 26, 2009 Report Posted June 26, 2009 (edited) if you are having to jump start it, clean the battery cables and tap the starter. Let me know where you find em cause i'm sure mine need clening OH YEA do not take for granted the compression is good just because it has 12 hours on it. CHECK IT!!!! Edited June 26, 2009 by slopoke Quote
drunkietheclown Posted June 28, 2009 Author Report Posted June 28, 2009 (edited) was the battery hard to find for a jumpstart? :biggrin: brain fart no idea how i got jump starting mixed up into push starting. Edited June 28, 2009 by drunkietheclown Quote
