My friend has a banshee it has t-5's v-force 3 cages and reeds trinty 2-1 carb/intake open k&n filter just rebuilt top end with bore over .60 pro lite pistons all new gaskets 19 cc domes with a cool head its pushing 160 psi on both cyls have the timing +4 with a high output rick stator 200 stator at this time running 110 with 32:1 amsoil
now heres the problem we got the motor back from the guy who built it and put it in the bike. we tried to tune the carb which has a 180 main and a 85 jet and so far all we get is hardstarting and when we get it started it will back fire when shifting to second and will bog down and die (also has a hard time idling) also when we pull the plug its black put new ones in and the same thing pulled the plug and black
Edited by bansheejuggalo
sounds like jetting but ive also heard that the newer Ricky Stators are junk. hell it might be a mix of the 2. if he has the stock stator laying around put it in and see what it does then if it still does it. it could be jetting etc
I was thinking that the jetting was wrong but if it backfires thats tomuch gas right but i c guys with the same set up running 200 mains and 95 jets
