vdubn Posted June 23, 2009 Report Posted June 23, 2009 Ok, so I have just picked up a set of big bore stock cylinders with pistons, etc., and a set of cases that will be matched to the porting on the BB jugs, so needing to sell my current setup. I have a set of cases that are match ported with the jugs, the jugs are polished nicely on the outside, and sitting at .080 over right now, so one more bore left. Current bore is in good shape, engine still runs very hard. I had done a compression check and got 120psi, but after discussing with a local builder, he said that was due to the port work that had been done. Still fires up on the first kick, and feels great, and is still running right now (taking it out this weekend to the sand). Worse case, throw some rings on it, and it should be good, but should even run as is. I will be pulling this all apart late next week, and here is what is included: - Ported Jugs, polished on the oustide (ported by Havoc, and the motor ran consistent 4.3's in the 300ft on Alcohol with a 4mil stroke). - Std. Wiseco Pistons - .080 over - 2mm spacer for under the jugs (can use this or get 795 series pistons if you don't like the idea of the spacer). - Stock head cut for Alcohol Selling the whole setup for $400 shipped within the lower 48 states I also have the cases with the matching port work done to them. The case is in good shape, but missing a chunk from some chain incident. Its the upper area above the sprocket, no issues with leaking or damage around the front of the sprocket. Cases seal well. The drain plug needs to be sealed to use as is, and doesn't leak, or get a +1 size from Yamaha. $110 for the bare cases shipped within the lower 48 states. Here are some pics of the engine, tomorrow I am putting on a Cool Head for the weekend run, and will take some pics inside when I pull the head off. You can see how much of the case is missing from the chain incident. Quote
87sheerips Posted June 23, 2009 Report Posted June 23, 2009 Bump for a sick ass motor! Someone in MI buy this thing! Quote
vdubn Posted June 25, 2009 Author Report Posted June 25, 2009 I decided I am going to run the bike as is for this weekend, and it will all come apart next week. I will post some pics next week for anyone interested. Quote
