robert0762 Posted June 21, 2009 Report Posted June 21, 2009 I am pretty sure it is a high temp paint cause its still on there and reg paint stripper did not get it off . I got the pipes like that. So can I get the paint off without ruining the chrome under it cause it looks half decent in the spots where it peeled some. Quote
fastrthnu Posted June 21, 2009 Report Posted June 21, 2009 Use that gel stuff I forget what its called, some kind airplane grade stripper. they have it at ace. if that doesnt work try using laq. thinner. I know some paints are really hard to get off, like on a clutch cover, I had to blast most of it off. Quote
1996dragshee Posted June 21, 2009 Report Posted June 21, 2009 It's just that aircraft remover.they sell it at Murrays or most auto parts stores.it comes in a spray can and also the tin jug.The tin jug is a better deal though.Just brush it on (wearing gloves cuz the shit burns) and wait a few minutes and it starts to bubble and wipe it off Quote
gregrob Posted June 21, 2009 Report Posted June 21, 2009 The aerosol can of Aircraft Stripper from walmart works well.. Either that or the gel will do the trick. I like the aerosol just DO NOT breathe it. Seriously, I usually dont worry about breathing in a little vapor if I'm using spray paint, etc but this stuff is hard core and will take your breath as well as causing who knows what kind of damage to your lungs. I'd grab some cheap paper face masks to use with it if you use the aerosol. And rubber gloves as mentioned if you get the gel stuff in the can/tub. Quote
