chaisson70 Posted June 20, 2009 Report Posted June 20, 2009 Does anyone know what the operating temperature is for a Banshee? Quote
LiftdT4R Posted June 20, 2009 Report Posted June 20, 2009 Anwhere around 180*F or so, you should be much higher then 210*F or so. Quote
chaisson70 Posted June 20, 2009 Author Report Posted June 20, 2009 Anwhere around 180*F or so, you should be much higher then 210*F or so. What about 230? That's what I'm running. Quote
Snopczynski Posted June 20, 2009 Report Posted June 20, 2009 210 is shut down temp. After that you can occur motor damage. Quote
LiftdT4R Posted June 20, 2009 Report Posted June 20, 2009 Ahhh, typo, my original post should read "you shouldNT be much higher then 210*F or so." I typically run around 170~180 when I'm out, I'll hit 200 on the tighter trails. 230 is def too high. Quote
Chariot Performance Posted June 20, 2009 Report Posted June 20, 2009 Ahhh, typo, my original post should read "you shouldNT be much higher then 210*F or so." I typically run around 170~180 when I'm out, I'll hit 200 on the tighter trails. 230 is def too high. I will be posting a serious banshee coolant impeller improvement next week. This impeller will do a significantly better job than pro design style impellers on keeping coolant temperatures lower and more consistant. Jerry Quote
LiftdT4R Posted June 20, 2009 Report Posted June 20, 2009 I will be posting a serious banshee coolant impeller improvement next week. This impeller will do a significantly better job than pro design style impellers on keeping coolant temperatures lower and more consistant. Jerry I'll keep my eye out for that. I just had my clutch cover off too. :ohmy: Quote
