Dunemasta Posted June 17, 2009 Report Posted June 17, 2009 Just wouldering what jets, main and pilot some of you are running I'm running a 225 main and a 52 pilot and a can't get my pyros to run under 1200 when climbing a dune Quote
Snopczynski Posted June 17, 2009 Report Posted June 17, 2009 pilot and main are too rich. Your needle is too lean. What needle is in it? Quote
Dunemasta Posted June 18, 2009 Author Report Posted June 18, 2009 (edited) Stock needle 3rd clip the plug is running a brown a little on the dark side its not wet thow, If I run any leaner the pyros tell me that i am running way to hot. Edited June 18, 2009 by Dunemasta Quote
Snopczynski Posted June 18, 2009 Report Posted June 18, 2009 The pwk does not come on the banshee, so there is no stock needle. What needle is in the carb? Quote
Dunemasta Posted June 19, 2009 Author Report Posted June 19, 2009 What ever comes with it from trinity racing Quote
Snopczynski Posted June 19, 2009 Report Posted June 19, 2009 Hey guess what, if you want help, your gonna need to pull the needle out and tell me what it is. I don't know what comes in it from trinity. Even if I did, I would still want you to double check the needle size to make sure they give you the right one, or to make a decision on which direction to get it running right. So pull out the fucking needle and see what size it is. I wouldn't buy a part from them if every other part sales company on the planet was going to give me leproacy. Quote
J-Madd Posted June 19, 2009 Report Posted June 19, 2009 Hey Snop, I need some help with a single 35 mm also, for a friend. 300 ft elevation. I don't know what's in it now, but I can check. In general what would you recommend for this? Thanks Quote
Snopczynski Posted June 19, 2009 Report Posted June 19, 2009 Base is usually eek or eej needle, middle clip position, 195 main, 42-45 pilot at 1.0-1.5 turns out on the air screw. Quote
J-Madd Posted June 19, 2009 Report Posted June 19, 2009 Base is usually eek or eej needle, middle clip position, 195 main, 42-45 pilot at 1.0-1.5 turns out on the air screw. Thanks Snop :beer: :beer: :beer: Oh, I forgot to mention that he's running SSTs if that matters. Either way, thanks for the starting point. It's pig rich on bottom right now. Quote
Snopczynski Posted June 19, 2009 Report Posted June 19, 2009 People have the tendency to set the pilot jets in them way too big. Quote
