Anyone have a guide or a link to a guide with photos, or a step by step on how to replace the rear brake pads?
Mine sounds like metal on metal when i stop so i figure they are gone.
Thanks
Just remove the 2 bolts that hold the caliper to the carrier (12mm wrench) Remove the two bolts with the locking tab plate and the pads fall right out. Use a c clamp or a piece of wood to push the piston back in. (be sure to open master cylinder cap) and install new pads. Depress petal a few times and check fluid level.
