4StrokeKilla Posted June 10, 2009 Report Posted June 10, 2009 :sad: ok i took my shee out yesterday and it started up right away and everything i let it warm up then got on it and took of but when i would punch on the throttle it wouldn't responed right away then i shifted and it sounded like if one of my pipes was only working the other one just didnt work :sad: so i tried it again and they both worked but after a while it kept on doing it again Then when i left it there turned on one of my carbs started to leak gas but big time though HELP HELP :shrug: Does anyone now what could be the problem? :shrug: Quote
robert0762 Posted June 10, 2009 Report Posted June 10, 2009 Pull your plugs and look at them sounds like you could have a stuck float and be flooding her out Quote
4StrokeKilla Posted June 10, 2009 Author Report Posted June 10, 2009 Pull your plugs and look at them sounds like you could have a stuck float and be flooding her out Well imma replace my plugs But do you kno anyhting else that could be the problem cause i dont wat her to blow on me or anything that ill have to waste big bucks on to get her fixed Quote
Drewski Posted June 11, 2009 Report Posted June 11, 2009 clean the carbs float pilot jet most likely sticking Quote
