madzx2 Posted June 10, 2009 Report Posted June 10, 2009 i have a 1994 polaris storm 800 project and would like to trade for a banshee project. comes with 3 stock cylinders, 3 big bore 860 cylinders that are ported and wiseco pistons, 6 heads, two complete cranks, 6 reed valves, lightwieght aluminum trailing arms, polaris plastic race skis, cometic gasket kit, 2 hoods, and many other spare parts. needs crank seals and a primary clutch to run and drive. $2000 invested. looking to trade for a banshee in comparable condition. im located in north-western wi. [email protected] 715-220-8972 pics can be seen at http://www.snowmobilefanatics.com/gallery/...x2/display.aspx Quote
banshee_terror_ Posted June 10, 2009 Report Posted June 10, 2009 ttt what did you have the torqe converter kick in at. the tracks studded at all Quote
madzx2 Posted June 10, 2009 Author Report Posted June 10, 2009 what did you have the torqe converter kick in at. the tracks studded at all i dont remember what rpm it engaged at but i think somewhere between 4500 -5000 rpm and it should run at 7800 rpm fully shifted out. the track has 200 studs in it i believe. let me know if you have any other questions. Quote
LegalizeFreedom Posted June 17, 2009 Report Posted June 17, 2009 i dont remember what rpm it engaged at but i think somewhere between 4500 -5000 rpm and it should run at 7800 rpm fully shifted out. the track has 200 studs in it i believe. let me know if you have any other questions. Is it a 121"? Those Storms are pretty sick, I had this custom sled a few years ago. Check out the link below. 97 SKS 700 136"x2" Mountain cat paddle, SLP power dome, Wisecos, K&N, VF3 reeds, Flat slides, SLP boost bottle, Jetted, SLP twin pipes/silencer, Comet primary & secondary clutch kits, Fox shocks all around, fiber glass hood. 50/50 Gas/AV, always Klotz. Other pictures are from other custom & stock toys. http://imageupper.com/g/?S080001003R2452248731865625 Quote
