bassmaster345 Posted June 6, 2009 Report Posted June 6, 2009 First off here is my specs: 89 shee Pro Design cool head with 22cc. domes stock bore and stroke with no port work FMF fatty pipes( I know wrong pipes ) Trinity 2-1 PWK 35 with no air box, 200 main, 42 pilot, DEK needle +4 timing 1350 ASL 85 degrees 40/1 Klotz supertechniplate with 91 octane pump gas http://www.flickr.com/photos/15592546@N08/3599436136/ Now my problem, I have a bog just off idle that I just cannot get rid of. I have tried needles DEK, EEJ and EEK, mains I have tried are 190 on up to 200, and pilots 38 up to 52. It runs best with 200 main DEK needle and 42 pilot and the plug chop is the one I posted. I just went through this motor and replaced almost everything inside and out, I did a leak down test and it held for over 6 minutes with no leak. It did the same thing with the dual stock carbs before I rebuilt the motor so I am wondering if it may be my coil or CDI? I checked the stator and it checked out ok. Coil reading between the two wire connections is 0.3 ohms. Thoughts? Quote
Ineedmoney Posted June 6, 2009 Report Posted June 6, 2009 Yes my banshee does exactly this and it started after a lon gtime of sitting. i dontknow why ether but im taking it somewhere tommorow to finnaly see. Quote
bassmaster345 Posted June 6, 2009 Author Report Posted June 6, 2009 Yes my banshee does exactly this and it started after a lon gtime of sitting. i dontknow why ether but im taking it somewhere tommorow to finnaly see. Cool, let me know what you find out. Quote
AKheathen Posted June 6, 2009 Report Posted June 6, 2009 (edited) what's your cap to cap, or cap to ground reading? pickup gap? did you guys try new plug caps? Edited June 6, 2009 by AKheathen Quote
bassmaster345 Posted June 6, 2009 Author Report Posted June 6, 2009 Not yet, got a new coil on the way so hopefully that will get it goin. I didn't get any reading on testing from cap to cap or cap to ground. Quote
bassmaster345 Posted June 11, 2009 Author Report Posted June 11, 2009 Got another coil today and runs much better without a bog. Now I just need to pick up a good set of pro circuit pipes and I should be good to go. Quote
AKheathen Posted June 12, 2009 Report Posted June 12, 2009 i've been seeing them for sale lately decent pricing Quote
