liveordie72089 Posted May 23, 2009 Report Posted May 23, 2009 I have had this problem for awhile. Its got me to the point where I'm about to put the banshee through a high rev and leave it. For some reason if I push in the clutch put it in gear while still holding the clutch I can't move. Does anyone know what could be the problem I have messed with basically everything. I might just end up parting the engine and bike out. Thanks. Quote
KaosBanshee44 Posted May 23, 2009 Report Posted May 23, 2009 You have to ease out the clutch and ease in the gas at the same time so that it doesn't stall on you. Glad i can help Quote
TNTS355 Posted May 24, 2009 Report Posted May 24, 2009 I have had this problem for awhile. Its got me to the point where I'm about to put the banshee through a high rev and leave it. For some reason if I push in the clutch put it in gear while still holding the clutch I can't move. Does anyone know what could be the problem I have messed with basically everything. I might just end up parting the engine and bike out. Thanks. Im a little confused as to what you are doing. Im sure that we need a little bit more information. Quote
liveordie72089 Posted May 24, 2009 Author Report Posted May 24, 2009 Uhm lets see. I put my bike in gear just push down and shove it into 1st. Hold in the clutch and try and push the bike. Well it doesn't push. I have no clutch at all. If I try and kick start the bike in first while holding in the clutch lever my bike will move like I have NO clutch. Quote
2/2 many banshees Posted May 24, 2009 Report Posted May 24, 2009 is the bike cold when you do this?? do you have oil in it? Quote
liveordie72089 Posted May 24, 2009 Author Report Posted May 24, 2009 is the bike cold when you do this?? do you have oil in it? Has oil and doesn't matter cold or not still does the same thing. Ive tried adjusting the bolt inside the clutch cover made sure the ball was in the clutch part. maybe I'm not doing it right. Also I may add. I did change the Push lever Assembly. Its not straight but every time I take it out pull it up and switch it up it goes right back to the same place. Maybe it has to do something with that? Quote
