wvbanshee1976 Posted May 23, 2009 Report Posted May 23, 2009 here is my set up i got 66 mm k&t drag ported cylinders 38 pwk carbs and 4 mill crank 19 cc domes running vp 110 gas 170 main clip in the middle 58 pilot jet i can shift through the gears and it will not accerlate pull the clutch in it revs fine pulling my hair out trying to figure it out any help would be appreciated Quote
2001Stroker Posted May 23, 2009 Report Posted May 23, 2009 Are your axle bearing on the verge of seizing up? How hard is it to push in neutral? Have you always had that rich of jets? That seems kinda fat to me. Have you talked to Kim at K&T about your jetting? Quote
wvbanshee1976 Posted May 23, 2009 Author Report Posted May 23, 2009 Are your axle bearing on the verge of seizing up? How hard is it to push in neutral? Have you always had that rich of jets? That seems kinda fat to me. Have you talked to Kim at K&T about your jetting? axle bearing is in great shape putting into neutral is easy ive got a overide tranny this is a new setup for me not sure about the jetting havent talk to kim i bought these ctylinders off someone else that they drag ported would they take my call Quote
2001Stroker Posted May 23, 2009 Report Posted May 23, 2009 You mean, would Kim take your call? Hell yea, man. He's good people. If it's his portwork, I know he'll help you out, on getting it right. Quote
sleeper06 Posted May 27, 2009 Report Posted May 27, 2009 Dont know much about his porting,my 4mil drag port,stock cyl,likes 190 mains,52 pilot,definitally call this guy tho Quote
